Apply IPv6 IS-IS accept policies globally. Use IPv6 IS-IS accept policies to filter incoming IS-IS routes the device receives over the SPBM cloud.
After you apply the IPv6 IS-IS accept policy filters, the device removes and re-adds all IPv6 routes with updated filters.
IPv6 IS-IS accept policies are disabled by default.
After you apply IPv6 IS-IS accept policies globally the application can disrupt traffic and cause temporary traffic loss. After you configure the IPv6 IS-IS accept policies value to Apply, the device reapplies the accept policies, which deletes all of the IPv6 IS-IS routes, and adds the IPv6 IS-IS routes again. You should make all the relevant accept policy changes, and then apply IPv6 IS-IS accept policies globally at the end.
If the route policy changes, you must reapply the IPv6 IS-IS accept policy, unless it was the last sequence in the configuration.
Enable IS-IS globally.
Ensure the manual area exists.
Ensure the IPv6 IS-IS filter exists.
Change the VRF instance as required to apply IPv6 IS-IS accept policies on a specific VRF instance. Not all parameters are configurable on non-default VRFs.
- Select IS-IS.
- Select the Accept Global tab.
- Optional: Select a name from the list or enter name in the DefaultPolicyName field, to specify the route policy name for the default filter.
- Select Apply to apply the default policy.
- Select Apply.
Accept Global Field Descriptions
Use the data in the following table to configure the Accept Global tab.
Name |
Description |
DefaultPolicyName |
Specifies the route policy name for the default filter. |
Apply |
Applies the default policy when you select apply. The device only activates the default policy if the route map (the default policy name) has a value. If you do not select apply, the device takes no action. The GRT always returns no action. |
NickNameTableSize |
Shows the IPv6 IS-IS In Filter nickname table size. |
IsidTableSize |
Shows the IPv6 IS-IS In Filter I-SID table size. |
NickNameIsidTableSize |
Shows the IPv6 IS-IS In Filter nickname I-SID table size. |
IsidListTableSize |
Shows the IPv6 IS-IS In Filter I-SID List table size. |
NickNameIsidListTableSize |
Shows the IPv6 IS-IS In Filter nickname I-SID List table size. |
